After reading the thread on alternative drain fields it prompted me to think about my septic system. Which does have an alternative drain field. The PO of the home rarely lived here so when we bought the place the guy that inspected it said it didnt need pumped and actually added some water to it. Fast forward 4 years and I figured I'd pull the lid and check it out. 1st there was no filter I could see, just the outlet stand pipe. I wrapped a section of cheese cloth around a stick and to avoid the scum layer i went down through the outlet. I swished the stick around at the bottom and there doesn't seem to be any discernable solid layer. Then i probed the scum layer. It was about 4" thick. So 4" of scum, 50" of water and not much of any solids. Does this seem correct?
Edit: there are 3 people in the house . With work and school we probably use it for solid waste 2 to 3 times per day.
