I had to order my stove pipe adapter ( part that sits on the outlet of the stove and goes into the double wall stove pipe) seperate from my stove and chimney pipe- the place I got the stove and chimney pipe didnt have the adapter - anyway when I set it on the outlet of the stove it is Very loose. The Inside diameter of the collar comming off my stove is 6 inches diameter and the outside diameter of the inner pipe of the adapter is 5 5/8 inches.
Will this be a problem and how are the adapters normally attached to the stove outlet collar? Could it be that I dont even need an adapter for my stove?
thanks for any help here guys.
My stove is the Pacific energy T -4.
This is what I got
http://www.northlineexpress.com/itemdesc.asp?ic=5SE-DSP-6SA
I am asuming it sits down on the stove just as pictured with the crimped end up?
This is what I got
