goody1006 said:
(much trimmed) New to the forum (posted about this splitter yesterday in a different section of the forum--not seeing this area--my bad!)
Welcome to the forum, hope we can help you out...
I have an older gas (have no idea exactly how many ton--hubby had it built) horizontal unit, that I can't move,
service or start by myself.
I've a bad shoulder/back that prevents me from using anything requiring a 'pull' start, so I've been replacing everything
around here with one, that I can afford to do.
One option that would help with the starting is to consider getting an electric starter - many OPE engines can be retrofit with one, or can be replaced with an engine that does have a starter. (Some starters will run on 110AC, others will take a 12 volt motorcycle or car type battery) However a Horizontal only splitter might not be your best option as it requires that you pick up rounds to get them up to the splitter. I find it easier to use a vertical splitter, others seem to like using vertical to bust up the big rounds and then going horizontal to finish up the chunks and smaller rounds. A lot may depend on just how your back and shoulder deals with the different sets of motions and lifting involved...
For moving the thing around, do you have a lawn tractor or ATV, etc? If so can you get an appropriate hitch put on it?
I like the fact I can just plug it in and go--without the mess of gas.
This one also seems small enough that I can move it without someone's help.
While the Ramsplitter is likely smaller and lighter than what you have, judging by your description, I would not consider any splitter in that size class likely to be "small and easy to move". In order to deal with the forces involved, you flat have to use a certain amount of steel, there is no way around it... However it will probably be easier at least. I would still look at getting some sort of "yard mule" and putting a hitch on it rather than shoving the thing around by hand...
In terms of the gas / electric tradeoff, it's a mixed bag - electric is easier in terms of plug in and go, but it hurts in that you are limited to only being able to work in places where you can plug it in.... Gas can be used anywhere you need it to be...
I'm reading there's some difference of opinion between 110-vs-220....I've outlets without any other pull on them which I would be using (110) but could access my dryer's plug without too much hassle, if need be.
Also--I'm a bit confused as to which extension cord to use.....12 or 10??
OK, let me try to put it in non-technical terms... starting with definitions, in many ways electricity acts like water pressure, and it can be easier to think of wiring as being like plumbing... Voltage is the electrical "pressure"
Current is the amount of electrons going past a given point in the wire. Power is the ability of electricity to perform work, and is equal to the Voltage times the Current. Wire gage is the size of your electric "pipe"
When you run electricity through a wire, it looses a certain amount of power as it goes. How much is a function of the size of the wire, the distance traveled, and the amount of current being used... The Ramsplitter, or any other electric splitter is going to draw a LOT of power, so it will cause a sizable power drop. Using a 10 gage extension cord will reduce the amount of drop, because it's a bigger cord (Electric cord numbers run backwards - the lower the number, the bigger the wire)
110v vs 220v is a question of the amount of electrical "pressure" being applied across the wire, and because electrical power (ability to perform work) is a function of both the voltage and the current, increasing the voltage lowers the current needed to get the same amount of work done. Thus the BEST approach is to use a 10g power cord, and wire everything for 220v - this minimizes the power lost in the cord, and will give you the most power at the splitter. It is also very important to keep the length of the power cord as short as possible... Note that you might or might not be able to run safely off your drier outlet - check w/ an electrician, I don't want to go into wiring details here...
[/quote]Depending on the severity of the winter, amount of insulating snow on the ground, what type of wood I'm burning, etc...I can burn between 2-4+ chords of woods a season, so I'm hoping this splitter can handle 4 chords a year without problems.
You might have to play with the wood a bit more, in terms of nibbling away at the edges, or planning how to work the splits, but I would expect the Ramsplitter to have no trouble w/ handling that kind of quantity, or kinds of wood.
Gooserider
