Hello, I have an older Blaze King wood stove insert (non-cat) = approximately 1982. I believe it may be the KFF-402. The thermostat coil had an L leg shape that slipped into the end of the second rod that controls the air damper. Somewhere along the line, the L part broke off so the coil is no longer attached. I can't find the part anywhere to replace the coil. Furthermore, it seems that the rods might need to be tensioned properly upon replacement? Unclear about this part. Can I simply remove the coil and bend a new L in it and put it back on? Or, would that throw off the thermostat specifications?
I'm sorry if these are basic questions. I would really love to continue to keep using my old trusty Blaze King, but the air intake is not adjustable since the thermostat coil broke. I can, however, move the rod manually with a tool, but that kind of defeats the whole purpose since it's meant to adjust by the heat.
Any ideas or input are greatly appreciated. I know this model is obsolete, but I don't have $5000 for a new unit and don't want to throw in the towel over a coil.
