This summer I took down the top 15 feet of rapidly deteriorating block chimney that had been used to vent our P-43 for the past 5 years. We've chosen to keep the lower section of the chimney that both supports the house as well as an interior field stone fireplace that the stove sits in front of. My plan is to core drill out through the the fireplace's firebox to the exterior, install a clean out T, 3' vertical pipe and then appropriate termination. I also plan to clad the exposed black remainder of chimney with 1" of foam and cover that with board and batten to match the cabin. We're in a high snowfall area and I'm wondering what would be the most appropriate termination of the vertical vent or even if my plan makes the best possible sense.
What would be the most ideal termination of exterior vertical pipe? Thoughts in general?
![Seeking advice regarding venting Harman P-43 Seeking advice regarding venting Harman P-43](https://www.hearth.com/talk/data/attachments/315/315847-281831b12a6d559af85117919edd038e.jpg)
![Seeking advice regarding venting Harman P-43 Seeking advice regarding venting Harman P-43](https://www.hearth.com/talk/data/attachments/315/315845-23de5b9c082b8b75188d91e636e2b728.jpg)
![Seeking advice regarding venting Harman P-43 Seeking advice regarding venting Harman P-43](https://www.hearth.com/talk/data/attachments/315/315846-2b7eb9647051ccf5c1336853c2e7c03c.jpg)
