Hi All - I am very happy to have found this community over the wknd !
My wife and I purchased our first home (split-style) this time last year. The house has a brick chimney and there is an old wood burning fireplace insert inside that we would like to use this winter. It is a Sierra Model 4200 Regal Fireplace Insert.
We just had our chimney repaired (top rows looked loose so we had them removed and rebuilt, installed 2 new clay flues and caps).
Our house was built in 1953, and the wood burning fireplace was installed by the original owners in Dec. 1982 (the year I was born !). The people we bought the house from lived there from 1989 - 2014 and said they never used the insert.
Fireplace is located in our living room. We have a pretty open floor plan. Dining room is right next to Living room and if your back is to our fireplace you would be facing a small stair case leading up to our bedrooms (no door in the way). In my very limited knowledge I am thinking that is good because the heat will be pushing out into the living room, rising and making its way straight up to the bedrooms - does this sound realistic ? Also, my insert does not have a blower currently but the old product brochure I have says:
"The Regal has not one, not two, but three large air convection channels, completely surrounding the combustion chamber. The aerodynamic design (patent pending
induces the flow of air through an air chamber under and behind the firebox and out over the top, into your room.
But unlike any other make, each side of the Sierra Regal fireplace insert is a venturi-style airflow chamber in itself. Unique air guide vanes pull cool air in at the bottom front of the firebox, moving it back and up along the heated plate steel sidewalls. there it picks up heat and expands, and warmed air is thrust forward and out into your home at up to 75 cubic feet a minute - without a blower ! More than any other fireplace insert."
The brochure goes on to say OPTION: Blowers (designed to attach after initial installation) are available for those desiring increased output of Regal Insert. Do you think I should consider purchasing a blower - if so which one do you think might work with my insert ?
Attached is a picture of the insert we have. It is a Sierra Model 4200 Regal Fireplace Insert - specs are below.
I would like to replace all door gaskets but I am not sure how to determine what size I need. Also aside from the door gaskets are there other gaskets (glass gaskets ?) I should look at replacing ? It looks like the unit has the standard 4 1/2" x 9" x 1 1/4" gray fire bricks and I don't see any that look cracked (some are pretty clean and some are pretty dirty though). I do not see any cracks in the body of the unit but maybe I'm not looking carefully enough - where should I be looking ?
Lastly, my father in-law and I pulled the insert out and there wasn't any chimney liner connected to it so I want to make sure that IF this unit can be used I put a very good chimney liner connecting the unit all the way up the chimney to the clay flue.
Pls take a look at the specs below when you can and let me know if there are any other parts I should test or replace. I very much appreciate your time and advice - if you have any additional questions pls let me know.
Thx again - joeyz101
Sierra Model 4200 Regal Fireplace Insert:
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
- 26"D x 28 1/2"W x 23 3/4"H - 500 lbs
- Heating Capacity - 2,000 Sq. Ft.
- Accepts 22" logs
- Front Loading and Air Tight
- Holds fire 8-12 hrs. on 1 load (seasoned hard wood, closed down ?)
- Extends on hearth 8"
- Shield 34"H x 48"W
