I've had a catalyst stove for a year now (bought a used Silent Flame from a neighbor) I replaced the combustor because the stove was 18 years old. The stove has a built in blower fan which I set to be controlled by the onboard thermostat. Once a certain firebox temp is reached, it runs the fan at either a low or high speed, depending on the temp of the firebox. Or it can be run manually at high speed anytime. I used the auto setting.
The stove seemed a bit fickle when it came to engaging the combustor because the flame would die down, which I understand is supposed to happen - a slower burn with a higher output due to the glowing combustor. But it could not hold the combustion temperature for long periods, even with a full load of wood burning well. I try to keep the combustor clear - vacuuming out the fly ash, etc. but eventually, I came to the conclusion that the stove does not like to have heat drawn from it by the blower fan. It burns far better for far longer without the fan running.
I am interested in any observations from others who have stoves with combustors and blowers.
One thing I am considering is to install a rheostat so I can run the fan at a low speed and get some heat movement without the cooling effect that the higher fan speed currently seems to produce. Plus it will be quieter.
