Hey All-
I know this question seems to get asked a lot and I've been around here long enough to have read a lot of the posts about it. However, I'm not satisfied with any of the prior discussion.
Background:
1. On my 4th season with my Princess - original cat
2. Burns have been going as anticipated/expected all season. Regularly getting 23-25 hours on a load and I'm on a once a day load cycle (in the evenings)
3. Cat probe thermo (a Condor) has been working as expected - my burns generally run about 11-12 o clock on my thermometer when cruising
4. Wood is a mix of 2 year old CSS red oak and some kiln dried wood I purchased this year (yeah, got behind on my wood processing)
Over the past week or so, I'm noticing a good amount of smoke coming out of the chimney about 3 hours into the burn. It happened tonight ( I load in the evenings). Was outside a bit ago and could smell smoke so I got my headlamp out and flashed the chimney. It was smoking like it does when I'm doing a reload (before closing bypass). At that moment, cat probe thermo was at 3p so plenty hot enough. Stack temps were 400F. I suspect if I go out and look in an hour, I will be back to a clear stack/no smoke.
I can't say I've ever noticed this much smoke coming out at this point in a burn before. Certainly had times, over the 4 years, where I've seen wisps of smoke coming off the stack but nothing like this.
Bypass seems to be operating normally. Doesn't feel like it isn't camming over all the way or completely shutting but I'm wondering if I've got a leak at the bypass?? Or maybe it's time to replace my cat? I do burn roughly 24x7 from November to March so it's possible I'm reaching end of life for the cat.
Any way, looking for thoughts and opinions from the brain trust.
Thanks!!
Background:
Thanks!!
