This pertains to a Lopi Endeavor 2020. When burning, the stove can be cruising along for 30-45 minutes with flue temps of around 600-650f. My normal cold start involves leaving it open until flue temps reach 600 then closing the damper and shutting primary air down to about 50%. I let the temps climb up to about 750f then start shutting it down bringing down the flue temps to 600-650f. After the fire settles in for awhile it seams like the secondaries switch on the afterburners and I can watch my flue temps climb all the way up to 850f with the primary air shut down completely.
I have approx. 21 feet with 2 45degree elbows. I emailed Travis Industries and was told that an inline damper is acceptable for this stove.
Would putting in an inline damper help with controlling the secondary burn or would that trap more of the heat in the stove and make the temps even higher? Am I over thinking this? Are these stoves supposed to burn that much hotter than their predecessors?
I emailed Travis Industries and am confused by the responses with Travis and hopefully someone here can elaborate.
Me:
![Lopi Endeavor.JPG Lopi Endeavor.JPG](https://www.hearth.com/talk/data/attachments/291/291501-bf219cbcfaf8fae31e65d78432cd4783.jpg)
Me:
I own a 2020 Endeavor. Sometimes after the secondaries take off it is uncontrollable. I’ll have air shot down all the way and watch my flue temps climb to 850f. Is it okay to install a key damper on this stove? I have duravent double wall pipe and would like to add the duravent adapter/damper. 6DVL-ADWD Travis Answer: Thank you for purchasing one of our units. Thank you for purchasing one of our products. Unfortunately to meet the current EPA requirement there has to be a specific amount of air to allow for a clean burn. There are several areas on the unit for the air supply that cannot be blocked or restricted. An inline damper would be fine. Me: Thank you for the response. Can you tell me what the recommended draft for this unit is? I can’t find it anywhere in the manual. Travis Answer: Not sure what you mean? Me: I figured the stove was designed and tested to work best at a specific draft measurement. Such as .3 in. H2O. Travis Answer: Draft is not part of the testing requirement so we don’t have any numbers. All of this from Travis Industries was from a guy with the following signature line: XXXX XXXXXX Customer Service/Technical Support Department NFI Certified Master Hearth Professional Travis Industries, Inc. |
