i realise I'm probably asking folk to speculate rather than draw from their experience... As few folk are likely to have had this issue
The secondary air inlet on the rear left of the Jotul F3 CB has a cast iron 'cover' screwed over it. This cover is approx 4" wide by 6" long. It covers the inlet on three sides, allowing air to flow upwards from below,through the open bottom part of the cover and from there it journeys a few inches into the small opening in the stove that is the inlet itself.
This cover must have a function, I assume that it mutes the flow of air into the burn plate a little... or...?
Anyway, I would like to invite those of you who know more than I do about this or similar setups to speculate - or indeed explain - what the effect would be on the behaviour/performance of the stove IF that inlet cover were absent.
So we're clear.. I am not in any way considering removing this cover as some sort of modification![Eek! :eek: :eek:](/talk/styles/default/xenforo/smileys/bigsurprise.gif)
Thanks... And happy February.. Wow.. Already!
