Hi all! I'm back. So, we've finally gotten stove worthy weather here in Virginia and I've got the IR burning OK, at least a lot better than last year. I attribute that to having seasoned wood over fresh split dead wood like last year. My question is, what's the ideal chimney height for this stove? I'm at 24 feet with two 90's (one into the wall thimble and one in the chimney putting it up the flue). All brand new insulated stainless steel flex liner, except the two sections of single wall inside the house. I'm thinking I may be getting too much draw up the flue, as my flue temp about 12 inches above the stove typically matches my stove top temp. I noticed that when my seconaries are kicking, it almost seems like they're blowing right up the chimney. I checked my chimney and when the secondaries are burning, it looks like a jet blast out the top instead of the slow lazy heat waves like when it's choked down for the overnight burn. Is it supposed to be like that or are my btu's being scattered to the atmosphere? Is there a fix for it? My thought process says that if I slow down the draft, the heat being sucked up the chimney will have more time to be distributed to the house. Any input?
