If wood does not sizzle or hiss, does that mean it is seasoned. I have some 3 year split red oak from neighbor. I run the air wide open on stove but it never gets above 450 with this stuff. Why wont it burn any hotter.
It can still burn without sizzle and not be seasoned. I'm burning some oak cut/split in the spring that measures around 30% m/c right now and it doesn't sizzle at all. The flame is lazy and the fire is slow to get going though.
Well part of the problem is that with the air wide open you're sending quite a bit of that heat right up the chimney . . . once you have the fire established try closing the air 3/4 . . . wait 5 minutes or so . . . if the fire is still going strong . . . try closing it to the half-way mark and again wait 5 minutes . . . if the fire is still going strong . . . try closing it to the 1/4 mark . . . what should happen if the wood is good and things are going well is that the secondary combustion (assuming you have an EPA stove with secondary combustion here) should kick in . . . i.e. Northern Lights, Bowels of Hell or BBQ Propane Visual Effects . . . and within a few minutes both the stove top temp and temp in the room should increase.
On our stove, the stove itself won't heat much until we turn the draft down. Leave draft wide open and on any stove most of the heat goes straight up the chimney. It is okay for the chimney (if it doesn't get too hot) but now worth a hoot for heating a home. Our draft control goes from 1 to 4 and to get a good burn we usually have the draft set from 1/2 the way to 1 or lower, but, we also have a cat stove.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
