- May 19, 2013
- 205
Lately I've had to nearly max out the combustion fan on a med feed rate to get a complete burn and not overfill the burn pot in less than a day. Factory feed settings for my Piazzetta Sveva for P4 (P1-P5)are Feed rate of 7 (2min-12max) and fan 2410rpm (1500min-2800max). I'm running 5.4 feed and 2700rpm which means the stove is putting out heat well below its capability to maintain a good flame.
My flame has a u shape around the drop chute which makes me think that I've got an air leak there. Unfortunately you can't get caulk behind the drop chute outside of the burn chamber because the stove was riveted and assembled in a way that you can't get to it without removing the hopper and control board. The chute is placed in the room blower/heat exchanger space that pushes the heated air out to the room. This also makes me think the problem is exacerbated when the room fan is on high. I did a test and looked at the flame when the room blower is off versus on high and the flames "U' widens when on high. The chute is welded to the cast iron fire box with only one spot weld at the bottom. Also found a sloppy caulking job at the top of the drop chute.
Oh yeah and the hopper is supposed to be silicone and gasket sealed but found a few spots where the gasket had a gap or silicone sloppily sealed. Pics attached. Any thoughts?
![Searching For An Air Leak Searching For An Air Leak](https://www.hearth.com/talk/data/attachments/120/120221-2ccbf2fcbd155e4aeaa2f5c0712b9b9b.jpg)
![Searching For An Air Leak Searching For An Air Leak](https://www.hearth.com/talk/data/attachments/120/120222-00fbdafb1818fcd02e80305f39539b98.jpg)
![Searching For An Air Leak Searching For An Air Leak](https://www.hearth.com/talk/data/attachments/120/120223-3860daedca252e9887926feb3c37ff84.jpg)
![Searching For An Air Leak Searching For An Air Leak](https://www.hearth.com/talk/data/attachments/120/120224-bb586c7fa064c7f9eaa8ef0d4acf7c9b.jpg)
![Searching For An Air Leak Searching For An Air Leak](https://www.hearth.com/talk/data/attachments/120/120225-bada3d00d24f2e0ef499756f3ee498bb.jpg)
![Searching For An Air Leak Searching For An Air Leak](https://www.hearth.com/talk/data/attachments/120/120226-de3a715b4a783ff57de25cc6f073d904.jpg)
