bostonbaked said:I spoke with a Technician at Dura Vent recently and asked him that question. His answer was to only seal the inner pipe with a bead of sealant where the two pieces over lap. He also said sealing the outer pipe joints is not the way they recommend. He said if the inner pipe is sealed correctly that's all that's needed. He went on to explain that the outer pipes purpose is to draw fresh air through to keep the pipe cool, He also said when installing the stove with an appliance adapter to never seal any part of the pipe other than where it slips over the stove outlet. He said if you do so you will negate the purpose of the outer pipe. He told me that if I were to be getting leakage at the joints the failure is on the inner pipe joint. Only fresh air is supposed to be in the outer pipe. He said putting a bunch of sealant of the outer pipe joints is only an attempt to solve the problem that lies within the inner pipe. This is direct from Dura Vent. If you check their site they have a diagram that shows where to put the bead of sealant.
JML1 said:After you use the silicone sealant how long should you wait before using the stove.
StoveMiser said:I have to say I have been very pleased with duravent. I have never sealed the joints and have never had a problem with leakage.....
macman said:StoveMiser said:I have to say I have been very pleased with duravent. I have never sealed the joints and have never had a problem with leakage.....
I agree Miser. I did my own install, and the only place I used Hi-Temp silicone is where Simpson said to use it....on the appliance adapter. Otherwise, I was told not to seal anything else by the local stove shop.
Have not had a single leak anywhere in the piping. Put the stove on High fan, and ran lit matches around all the joints looking for a flicker....nothing. I have CO detectors all through the house.....not a peep out of them.
slink said:JML1 said:After you use the silicone sealant how long should you wait before using the stove.
We install and fire the stove for the customer with in minutes of the last joint being sealed. Never had an issue with the silicone. An advantage is "if" there is a leak you can still remove the pipe and reseal before the silicone sets up.
If you bought that cheap crap at Home Depot I agree. The pro pipe is welded no rivets to speak of . You can leave a section unsealed out side to gain access for cleaning. How anyone can make a blanket statement as to what some tech. has in his or her home is a mystery to me. He or she (may) have far more experience burning than you or I. It's just your opinion.( actually Parrotheads sorry ) There is no way to know that. Don't shoot the messenger. You obliviously bought their crappy pipe so what makes you an authority ?richg said:bostonbaked said:I spoke with a Technician at Dura Vent recently and asked him that question. His answer was to only seal the inner pipe with a bead of sealant where the two pieces over lap. He also said sealing the outer pipe joints is not the way they recommend. He said if the inner pipe is sealed correctly that's all that's needed. He went on to explain that the outer pipes purpose is to draw fresh air through to keep the pipe cool, He also said when installing the stove with an appliance adapter to never seal any part of the pipe other than where it slips over the stove outlet. He said if you do so you will negate the purpose of the outer pipe. He told me that if I were to be getting leakage at the joints the failure is on the inner pipe joint. Only fresh air is supposed to be in the outer pipe. He said putting a bunch of sealant of the outer pipe joints is only an attempt to solve the problem that lies within the inner pipe. This is direct from Dura Vent. If you check their site they have a diagram that shows where to put the bead of sealant.
Oh, those people need to get a clue. Simpson whore a vent leaks six ways to Sunday due to its poor design and Fischer Price construction. Your best bet: assemble your piping, and then seal every seem joint rivet crimp bend notch gap turn etc you can find with rtv. Then, and only then, can you be sure that their crap product won't leak. If I did my job as poorly as they do theirs, I'd have been fired and sued years ago.
staplebox said:I initially sealed the inner joints and still had a leak. I tried adding rtv to the outside of the joints (including the outer bend if the 45, piece of crap) and still had a leak, and it looked like crap. I eventually ended up using high temp silicone tape. You can find if in the plumbing section. I wrapped it around every joint and the 45. Works great , holds fast, doesn't melt, easy to apply and actually looks nice.
Alan Kaf said:staplebox said:I initially sealed the inner joints and still had a leak. I tried adding rtv to the outside of the joints (including the outer bend if the 45, piece of crap) and still had a leak, and it looked like crap. I eventually ended up using high temp silicone tape. You can find if in the plumbing section. I wrapped it around every joint and the 45. Works great , holds fast, doesn't melt, easy to apply and actually looks nice.
Can you point the a URL for the exact tape you are using? Did you get it at a chain store?
There seem to be so many type, different backings, etc. Also you said it was in the pluming section -- I've seem some from an internet search that are for the electronics industry.
Thanks, Alan
Thanks, Alan
