I know, I know..it's the death stove.
I have a Logwood in my workshop. The previous owner of the house had a double barrel 55 gallon barrel wood stove, and apparently could get my half-insulated, very leaky shop so hot that he'd be sweating. I don't have one. I do have this crappy Logwood stove. It was left in the garage of a rental property I have, and figured, it's free..why not use it?
So, I scrubbed it down, painted it with engine exhaust paint, and sealed the door. Now I'm a bit lost.
I don't expect it to burn for a crazy long period of time, but this is kinda nuts. I have a thermostat on it, and I can barely get 400* out of a roaring fire on the top plates, while the pipe will read 6-700+. The stove appears to be a good casting, but it's leaky as heck - you can see flame through the plates on the top.
I'm thinking we need more sealing, but I don't exactly know what to do. Should I use asbestos cord (well, whatever the door seal is made of) to seal the panels to each other? Is there something adhesive I would be able to use to seal the thing? The best I can think of is copper Permatex stuff, but that's only rated to 700, and if I get an overfire, I'd be kinda screwed. Should I try to seal the ash cleanout?
Currently, the setup is that the stove is sitting on four cinderblocks, running a 36" pipe to a 90* bend, to another 36* pipe, through the corrugated steel wall (with a transfer box) with another 90*, then about 8 ft of pipe up the side of the shop to clear the roof. I have a grate inside, but am not running any kind of firebrick.
So, the TL:DR version:
1. Should I use firebrick in the bottom instead of the grate?
2. What can I use to seal the top plates?
3. Should I seal the ash cleanout?
4. What do I do to seal the plates to each other?
Thanks in advance guys...
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196075-478468f6eddaa8918d486ed5b8e756ce.jpg?hash=JzTC3IBOeP)
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196076-4a94e6325d49b082c37b8205a85ff224.jpg?hash=C5oypssoyj)
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196077-d08ab02a4c64c63c282aa51d026e078e.jpg?hash=FWASmU8w_Z)
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196082-82783e93c93d33b13583a2a758011727.jpg?hash=rOhOf8IYsX)
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196083-feb1be183a23c3aa741484ef65609d8c.jpg?hash=E7nzv8KcmY)
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196090-5da3b8a16ec9278aa46797d633cd92d3.jpg?hash=POCvKp8tY0)
![[Hearth.com] Sealing up a USSC 2421 [Hearth.com] Sealing up a USSC 2421](https://www.hearth.com/talk/data/attachments/196/196097-9decce160ba749246c76b9cba3452bee.jpg?hash=wZI2dvWaX-)
