Hello, I have put an insert in with an 8" exhaust where old fireplace use to be. In the process of clearing an area for the 8" flex pipe, I have a pretty big hole to seal near the exhaust pipe at insert per my picture and also a giant fireplace area. My question is, can I seal at the top of the chimney flu where the pipe comes out and what materials would you use for that? Would sealing at top be just as efficient with keeping heat in the house since there would be a void from top of chimney down to insert? I would much rather do this option because the it is a huge space just above the insert.
If sealing near the top is not as good of an option, what do you recommend for this huge gap in the picture and what materials?
Thank you so much
![IMG_2187.jpg IMG_2187.jpg](https://www.hearth.com/talk/data/attachments/316/316218-5c06ada0b5884bbf638d18e1f90bac34.jpg)
Thank you so much
