Masons who built our chimney recommended applying a sealer product called Chimney Saver to the exterior brick every 5 years. They warned me that without sealing eventually moisture may leak into the house and also that the chimney would deteriorate faster.
It's been well over 5 years since I last sealed it...we had a metal roof installed, for one, which makes getting around on the roof a lot trickier (it's 12/12 where the chimney is), and then I installed a solar array, which complicates things even more. I asked the masonry company if I could hire them to do it but they are always too busy (I don't think they really want to do the job anyway).
So I guess I need to gather up my courage and come up with a safe plan to get it done myself using roof ladders and a safety line (I installed the solar array so I can work on the roof if necessary but the older I get the less I want to). I'm curious if others are regularly sealing their masonry chimneys and how often this really needs to be done (I notice the Chimney Saver product has a 10 year warranty).
Thanks for any input.
![sealing a masonry chimney sealing a masonry chimney](https://www.hearth.com/talk/data/attachments/317/317078-a9480462eec6653b8f8ea397abcfa448.jpg)
