Hello all,
I am installing a Drolet 1400i Escape insert along with an insulated 6' flex liner and blockoff plate this weekend.
My house is about 25 years old, well insulated, 1200 sq ft 2 story with the insert being installed in a masonary fireplace opening in my living room on the first floor.
What is the best way to connect the flexpipe to the insert?
The connector that came with my flex liner kit has you attach the appliance connector to the flex pipe with 4 stainless steel screws. Im wondering if this is an effective way to connect the flex pipe to the connector. All other designs I have seen, the appliance connector uses a band type clamp to connect things together.
Which one is the preferred method?
Another question that I have is should I be using any sealant on the joints between the insert and the connector and the connector and the flex pipe? Im worried about air leaking at this joint. Just curious if any sealant is used at the joints.
Thank you,
Ryan
Thank you,
Ryan
