need a little hydraulic tutoring I am reviving an older built splitter (previous post monster splitter ) and have run the unit successfully through tractor hydraulics. currently powered by 17 hp three cyl. mitsubishi diesel. i got everything running and the pump noise makes me want to run away i thought the diesel would be the noise maker
!! The pump is ccw rotation old ramp truck pto and runs of front of crank . pump is a 17 gpm single stage. the fluid seems aerated and i think it may be starving on the suction side as i had to reduce inlet to 3/4 from 1 1/4. before i attempt to re-size feed to pump from tank does anyone believe that this is my problem??? or should i attempt a 2 stage pump ccw rotation seems to be limited
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
