I have an old Schrader, unsure on the year or model. My grandpa had bought it and used it for years as their primary heat source after they switched from coal. I now have been using it for a while. I noticed getting it hot was no issue. When it came to efficiency, that is where I was having issues. When looking I would notice that I had alot of wasted heat would go right out the back and into the chimney. After countless hours of research, I figured I should make myself a baffle. Got some 3/8in plate and went to town with the plasma cutter.
![Schrader fireplace baffle Schrader fireplace baffle](https://www.hearth.com/talk/data/attachments/318/318430-4402c8d672a9bb6a5442456054ed199b.jpg)
This is what I ended up with. I also added in a bypass with a shutdown for starting.
![Schrader fireplace baffle Schrader fireplace baffle](https://www.hearth.com/talk/data/attachments/318/318431-585df2acc6364576db08339d13ac7b0b.jpg)
So far, it's increased my internal temps at a consistent 580° and keeps my chimney temps down at around 350°. With this I am now able to run with the main damper almost closed while still maintaining a good flow out the top of my chimney. More testing will follow with efficiency and how well it holds wood overnight!
![Schrader fireplace baffle Schrader fireplace baffle](https://www.hearth.com/talk/data/attachments/318/318432-d5c17808db0288a2c5eaa3809b2f9abc.jpg)
![Schrader fireplace baffle Schrader fireplace baffle](https://www.hearth.com/talk/data/attachments/318/318433-bab564f480e99548e263dfe3552d7637.jpg)
![Schrader fireplace baffle Schrader fireplace baffle](https://www.hearth.com/talk/data/attachments/318/318434-83000b00c83526ca0e6fecfbbedc94cd.jpg)
