Hello All,
Mike here and I’m a newbie to this forum, but I’ve been searching a bunch on here today. I live in the Twin Cities of Minnesota, but was born in Wisconsin and am an avid Packer fan, but that’s beside the point. I’m a mechanical engineer and I love the idea of wood as an secondary heat source. I am starting to get quotes for a wood insert for a masonry fireplace which currently only has a screen and no glass. It has large river rock in the facade, and should work to soak up heat well. My family has land in Wisconsin that I can utilize for wood supply, and I just bought a Stihl MS 271 with 18” bar. I think I’ve finally got blessing from my wife to use some “found money” from childhood savings bonds. I currently am burning oak in an open fireplace from last year that is stacked and split under a roof with vented sides.
My home (see photo) : 2 story with flat roof, vaulted living room, 2700 square ft above ground with another 1300 in the basement, which is half finished and has a few heating ducts. There’s a second fireplace down there, but I am not looking to change the heating down there right now. The main floor fireplace is nearly in the center of the house, which I believe will help with trying to heat as much of the house as possible from the main floor insert. We have an awesome 2 stage gas furnace, with duct work that was set up for zoning when the house was built in 1971. It doesn’t have automatic zoning anymore, but there are still manual dampers where the ducts exit the plenum, so I can control where the air goes.
On to the real question. I’m trying to determine the appropriate BTU output that should be my upper limit. I don’t want to have the situation where I always have to choke the fire off and produce undesirable emissions and burn efficiency. I have found another user heating 3,000 sq ft with the Kozy Heat Z42 CD, which has a quoted rating of 60,000 BTU. That’s the only similar post I’ve found so far, but would be happy to read further if others know of posts that would help. I did read the “welcome” info with considerations for wood heat.
See the attached pano photo showing my main floor. Excuse the mess, I’ve got 3 little kids, and barely found time to write this post. You can see the location of the existing masonry fireplace, as well as the vaulted family room and stair to 2nd level where there are 4 bedrooms. 3 of the bedrooms are above the kitchen and fireplace, the master is beside the vaulted space. I doubt that the fireplace will heat the master, but I’d be glad if it did. The kids beds though should get heat rising through the floors right? Or would the heat go up the vaulted space and down the hall instead? I’m also wondering if the heat will wrap around to the kitchen, adjacent to the fireplace?
Bottom line: how do I make sure I don’t overheat the living space with the insert, but still maximize the heat to get as much of my 3,000 sq ft heated as possible? My fireplace box opening today is 22” high which is already a limiting factor. You can see large windows in the photo, but they don’t open, are double panes, and actually don’t lose much heat. I had an energy consultant estimate that the flat roof attic has an insulation of about R40-45. I follow my house temps during the daytime via a smart thermostat and with outdoor temps in the single digits, the house only drops to about the mid to low 60’s by the afternoon, from 68 when we wake up for work.
I’m sure I’ve missed some valuable info, so let me know.
Mike
Mike
