Hi everyone, new here and have some questions on a stove I just bought. It is a never-used, well-kept SCAN DSA 4 wood insert. I am planning on installing it in my existing, good condition masonry fire place. It is approximately 15 feet. I have read the manual -
www.manualslib.com
- and believe I can follow the standard procedures for installing from the insert up through to the top of the chimney. Here are my questions:
1) I understand this is a high efficiency / high heat model stove. I want to know if anyone who has the stove/has experience with the stove has a specific recommendation for what flue liner to use. I am thinking of a standard 316 flex steel kit which comes with a connector and insulated high temp liner.
2) Is it ok to use the universal connector that comes with this kit? I also noticed there is an oem flue collar available for this unit. Do I need to purchase the flue collar or is the connector all I need?
3) I have a tile hearth which extends out 18" from the face of the fireplace. I plan to raise insert approximately 3" from the floor of the hearth. The instructions recommend 1/2" mineral fiber protection extending 24". Can I use the tiling or do I need mineral fiber replacing it? Can I use the existing 18" and still be safe enough (6" shy of the 24" required).
Thanks for anybody who can help with this project!
Pete
SCAN DSA 4 Instructions For Use Manual (Page 10 of 19) | ManualsLib
![www.manualslib.com](/talk/proxy.php?image=https%3A%2F%2Fwww.manualslib.com%2Ffavicon-32.png&hash=9daad3f5cc1483e951324312106c27f5&return_error=1)
Pete
