Can anyone tell me what the realistic usage is of this stove? I've been told they burn about a bag a day. I'm going through a bag and a half at least. I'm now using LG Granules. Thanks!
flynfrfun said:Does the Santa Fe have an adjustable auger feed plate? If so, slide it so that it feeds fewer pellets and then run it on high. This will give more blower air, but use the fewer pellets as if you were running it on Med.
tjnamtiw said:flynfrfun said:Does the Santa Fe have an adjustable auger feed plate? If so, slide it so that it feeds fewer pellets and then run it on high. This will give more blower air, but use the fewer pellets as if you were running it on Med.
The only possible downside of that is that the combustion blower will be sucking a LOT of air for just a few pellets causing a lean condition and blowing ash and pellets possibly out of the pot. The combustion fan and the convection fan speeds are normally tied to the heat setting. It might work though.
flynfrfun said:Ahh...forgot about that. My M55 has a damper and a combustion trim so I can reduce the combustion blower's draw if need be.
Wales915 said:I'm in the same spot, trying to fine tune feed rate and blower settings... Of course a higher blower setting on the Santa Fe, means automatically increasing the 'feed rate'... My stove on Med blower, and factory set 60% feed rate, was actually shutting DOWN, because the dealer said the thermo coupler wasn't staying above 500 degrees So he set the control box to '7' instead of '6' which it comes from the factory set as ...
Well, the stove is still running, without shutting down , but I'm 1.75-2.2 bags a day and it's not even that hot in my place ?!? I'm only heating 950-1000 sq feet, and even with this crazy pellet consumption - cant get my heat in the next room to 70 ???
Any ideas?? Im new to the santa fe, but owned a bottom feed unit years ago, and it would keep the basement at 72-73 and the remainder of the house/ upstairs at 68-69 minimum ..
And help would be appreciated )
Scott in Central Ct
tomandy said:Thanks. I am new to this game and can use lots of info from seasoned users. You have provided me lots to absorb, thanks. My dealer said this unit works best on high. My instinct tells me to run on lower settings as the need calls for. I think this would provide more even heat rather than cycle the stove multiple times. Besides not being experienced with this stove, I have lots of misfires.
Wales915 said:I do have the Santa fe, just new to the forum... If the feed rate is set to high, can I still run on low or high depending on heat demands, without getting the exhaust pipes shuttering ???
Wales915 said:Thank you for your insight First yr with the Santa fe, and just trying to fine tune!! I'd rather not be burning so much 1.5-2 bags, and it's only been 40 outside, but, oh well... Pretty soon it may be cheaper to turn on the baseboard hot water!! Oil Yuck !!
I'd rather not have to supplement with the furnace if there is any way around it
-scott
Wales915 said:Home is nicley insulated, feed rate is slightly more open because of long pellets, just beyond the middle, and on medium... Almost 2 bags not quite, but can't get room temp at 69-70, and only heating about 800-900 sq feet ??
Wales915 said:No, but the L portion or my ranch is blocked off. Just trying to heat living/ open dinning room and 2 bed rooms, all right off the living room where the stove is.. Can't get it above 67-68 even on high, and it hasnt been that cold, and insulated wel
