I have never used a saw with anything other than the standard low kickback safety chain and am wondering about the advantage and disadvantage of other chains and how to know if I should try it or what one.
Tony , You have 8oo+ posts . I'm sure that You've read a lot on the subject of chains . The only way that You will know for sure about the other type of chains is to just try them . I've got this feeling that once You use a semi chisel ,or full chisel chain ,You'll wonder why it took so long to make the swapTony H said:I have never used a saw with anything other than the standard low kickback safety chain and am wondering about the advantage and disadvantage of other chains and how to know if I should try it or what one.
Tony H said:I guess a better question would be : What difference should I expect to feel when using the saw as far as kickback ?
I don't often have the saw kickback on me and even less often set off the chain brake.
I do understand chisel chains are much more agressive cutting than the reduced kickback.
LLigetfa - Obviously using a chainsaw any chainsaw is not "safe" I am just using the Industry reference of anti/reduced kickback or safety chain to refer to the type chain being used. Having worked in contracting and construction related industries for many years I understand the human element plays a huge role in preventing preventable injuries. I have witnessed several close calls and have seen a man shot across a room having encountered the wrath of a supercharged live capacitor due to not discharging and not practicing personal grounding able to prevent such damage. He was lucky and did live but I bet he never did that again.
Thanks for the offer I think based on some of the helpful suggestion I will put a semi-chisel on the 250 and give it a try. You can still stop by for a beer if you want I am about 1 mile off Rt90 not far south of 43 . PM if you want.Danno77 said:Tony, If you want me to stop by on my way up to Mukwonago, I'll bring Dad's MS250 with a semi-chisel so you can see the difference. Or just go get one for yourself. If you are comfortable with a saw there is no reason NOT to try it.
Dakotas Dad said:I replaced the factory "low kickback" chain on my 359 with semi chisel, and other then it cutting faster, I noticed no real difference in what was involved in running the saw safely. But, I think I already ran/run safe so that's why I didn't notice anything. I think if you run your saw sloppy.. that's when the thing can get you, regardless of chain. Wear gloves. eye protection and head protection when felling. Chaps. always. Don't run the saw when tired. I know for a fact that 3 tanks of gas is my limit. I don't try for a 4th tank ever, no matter where I am in the pile.
zzr7ky said:I keep the original safety chain in saw box for cutting stumps low, or the lower 6' of house yard trees. Then I don't feel as bad when I hit nails, rocks, dog collar, etc...
Nixon said:Tony , You have 8oo+ posts . I'm sure that You've read a lot on the subject of chains . The only way that You will know for sure about the other type of chains is to just try them . I've got this feeling that once You use a semi chisel ,or full chisel chain ,You'll wonder why it took so long to make the swapTony H said:I have never used a saw with anything other than the standard low kickback safety chain and am wondering about the advantage and disadvantage of other chains and how to know if I should try it or what one.
To Me safety chain is like using a dull knife . You'll start forcing it to cut and eventually it''ll come back to bite You.
Tony H said:Nixon said:Tony , You have 8oo+ posts . I'm sure that You've read a lot on the subject of chains . The only way that You will know for sure about the other type of chains is to just try them . I've got this feeling that once You use a semi chisel ,or full chisel chain ,You'll wonder why it took so long to make the swapTony H said:I have never used a saw with anything other than the standard low kickback safety chain and am wondering about the advantage and disadvantage of other chains and how to know if I should try it or what one.
I have a boiler and most of the time and posts were spent in the Boiler room so I have not read that much on the subject of chains. Think I might get by the Stihl dealer tomorrow and pick one up.
webie said:Tony H said:Nixon said:Tony , You have 8oo+ posts . I'm sure that You've read a lot on the subject of chains . The only way that You will know for sure about the other type of chains is to just try them . I've got this feeling that once You use a semi chisel ,or full chisel chain ,You'll wonder why it took so long to make the swapTony H said:I have never used a saw with anything other than the standard low kickback safety chain and am wondering about the advantage and disadvantage of other chains and how to know if I should try it or what one.
FYI you will probably have to sign off On a liability form for this chain . Also depending on your dealer he may or may not have it . If he does have I bet you will have to ask for it as it wont be open to JON Q Public .
On a flip side to this I actually have a reduce kick back chain On my one saw I use mostly for brushing I think it doesnt hook up as fast and pop the chain off the bar.
ApproximateLEE said:Release form is spewed hogwash!
Ever have to sign one when you bought a buck knife, gun,dirtbike,axe, Jack Daniels, Tripple whopper, or diamond ring? ;-)
I've never tried it on a saw that small but a full chisel, half or full skip may work allright. A big factor in saw performance if you go with full or semi chisel will be keeping your raker depth perfect.
