Howdy!
I have conflicting constraints in my stove alcove design, and if I put the stove at my preferred height, it will be closer than the manufacturer's specification for minimum distance to an alcove ceiling.
Now the alcove's ceiling is angled up at a 45 degree angle for natural convection circulation, so the stove only violates the spec at its rear edge. More significantly, common sense tells me the angled ceiling will trap less heat and circulate more air than a flat one (that's why I'm doing it).
But yeah, who can say how much better, what's safe, etc? BeGreen can just reply with "no", and I'll forget that idea. I fully expect that trial balloon to be shot down, but I'm floating it out there anyway.
A more promising route--does anyone have an idea/reference/etc. for a non-combustible ceiling design? The ceiling is over a 3' by 10' alcove, tilted at 45 degrees. It bears no weight except for itself, insulation, shingles, snow, and maybe me. How about metal studs covered on both sides with some sort of non-combustible sheet rock (cement board?), with fiberglass or some other non-combustible insulation behind?
On a related note, is plain (unbacked) fiberglass insulation fireproof? I know it shouldn't touch a Class A chimney pipe, but that's to protect the pipe from hot spots, right?
I'm just geeking out here. It would be nice to have the stove at the height I want, but I won't do it unless I can do it safely.
Thanks, and stay toasty.
