Hi everybody! I have a Blaze King Ashford 25 insert that I used as my primary heat all last winter. I only turned my furnace on when I was out of town. It was newly installed LAST summer and has exactly 1 year worth of creosote built up from near constant burning all winter. As winter approaches many of us are thinking about the maintenance of our wood heating systems and I for one have [had] ZERO experience sweeping a chimney.
HOWEVER, I am pretty handy and don't mind getting on my roof. When I called around and found that the going rate around SW Pennsylvania is about $200 for a sweep, I was convinced to DIY. One outfit told me the "Inspection" was 199 and the cleaning started at another $100.
Anyway I found and Purchased the Rutland 6" brush and went with POLY since I have a stainless steel 6" liner. It was $15 at HD. I also bought the rods there for another $29 so it was about 49 out the door.
MAN was it EASY!! The brush worked great. Upon inspection the only creosote I found was light brown and powdery and the brush fit in perfectly. It was just snug enough that it felt like it was abrading the liner perfectly but not too big that I was worried about dislodging or breaking the liner during the cleaning. Northline Express has some good how-to videos on YouTube and that is pretty much how I did it.
With just a screwdriver (for cap on top) and this brush system I was able to get it VERY clean with minimum effort. I just opened the damper, closed the front door and scrubbed away. Then I scooped out the soot with little effort.
If you are thinking about the Rutland chimney sweeping products they're great and you can DIY!
