Hello again, I recently got a stainless steel liner kit for my kuuma VF firebox, in order to install it I had to take the brick out, when I removed the floor brick I noticed at the back of the fire box, more so in the corners there was a lot of rust that had formed and when I took the scraper the steel pealed away, at the end of the season I removed the smoke pipe and cleaned the furnace. I have a dehumidifier 10ft for the furnace and a heat pump water heater in the basement so it stays pretty dry down there, where would this moister be coming from? My thought is when the ac comes on the cold air is coming in contact with slightly warmer steel? Im thinking I should disconnect the ducting and cap it after the heating season next year?
![Rust in vapor fire firebox Rust in vapor fire firebox](https://www.hearth.com/talk/data/attachments/299/299712-fcd835f62749fc1d2b3ff6a72f569526.jpg)
![Rust in vapor fire firebox Rust in vapor fire firebox](https://www.hearth.com/talk/data/attachments/299/299708-1d0e21b0ee3a9e01979f1ba32adc4087.jpg)
![Rust in vapor fire firebox Rust in vapor fire firebox](https://www.hearth.com/talk/data/attachments/299/299709-40815f53031ccfb377ca7121dea5c3ba.jpg)
![Rust in vapor fire firebox Rust in vapor fire firebox](https://www.hearth.com/talk/data/attachments/299/299710-65b11c939e6ea1060758230cc6dad0e8.jpg)
![Rust in vapor fire firebox Rust in vapor fire firebox](https://www.hearth.com/talk/data/attachments/299/299711-9b1c726e1f9074559b09a45f2dd383dd.jpg)
