Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I am wanting to buy a Russel Decton wood furnace. They have been out of business for some time. I had one in the 80's but left it in the house when it sold. I want to rebuild one. I will come and pick it up.
I bought one a few ears ago, an Energy King. Paid a lot for it. It burns twice as much wood a year as the Russel and I have to clean my chimney 5 times a winter. I had my Russel 16 years and never had to clean my chimney. The Russel was a great stove. I don't know why they went out of business. I never saw smoke come from my chimney. The Energy King looks like a steam train.
Those newer furnaces I mentioned, although a bit costly, are very efficient.
Sounds like the old unit you had was a gasser or, at least, your wood was primo dry.
Most likely, you'll have a hard time finding an old Russel.
You have sparked interest in me though. I'm looking online now for info on those old Russel units.
If you find anything let me know. I am in Rockbridge, Ohio. They had an after burner over the main burn chamber and were awesome. I can't understand why they went out of business. They would have easily passed the emissions test and were a fairly simple system. The bottem panel was hinged at the back and had clipps in the front. If the power went off, you could unlatch the 2 front clips and let the front down to the floor and it would work as a gravity unit. They were ahead of their time and worked great
That unit looks like it was ahead of it's time, but would be over 40 years old now...not worth the time or trouble to find and fix up what likely is exceedingly rare, and almost surely a crusty ole pile at this point. Once metal has gone through hundreds or even thousands of heat/cool cycles it changes the makeup of the metal and it's almost impossible to weld...it's just not workable anymore.
I second the suggestion of going with a modern furnace, which would be tstat controlled too, not manually fired like the Russell appears to have been. The Kuuma Vaporfire VF100 is top of the heap and a buy once cry once type of unit...the Drolet Heat Commander is the other one still made, but is still not cheap, and will likely not have the life expectancy of the stainless steel firebox VF100. Many happy n warm VF owners here...some were former EK owners too! I looked up that Russell furnace...only thing I found was a link to the owners manual... interesting!
Resembles a conventional style baffled woodstove. Increasing the size and adding a blower for forced induction turn it into a furnace.
Doesn't seem hard to fabricate, from your link I viewed.
The hard part is getting all the holes n passages the right size...plus getting home insurance with a homemade stove would not be possible...heck even an old Russel with a missing UL tag would not qualify either (assuming they were tested)
I was hoping to have a fabrication shop rebuild it to factory specs, put a new blower on it, rewire, reweld the box and make it like new. That furnace was amazing and simple, and easy to use. I looked at a vaporfire by Kuma. I talked to them and they had me call someone in Ohio to vouch for them. He wasn't very convincing that it was that much better for twice the money. They were my first choice but they seem complicated and hard for a person on a fixed income to justify. I can pay a lot of electric bills for 8 grand plus instillation. I want to buy American made
Yes I do have good hardwood. I have 45 acres of mostly hickory in the Hocking Hills of SE Ohio. hockinghills.com/enchantedacres
I keep it at least 2 years under a roof and right now have around 95 cords.
