Running the stove video?
corey21
2,249
Soutwest VA
Is the info good or bad?
That is how i start my fires.
Although it sounds completely crazy, try building your fires upside down. Couple of splits on the bottom with lots of criss-crossed kindling on top. Bigger kindling lower down and smallest stuff on top. Throw a couple of knotted (not scrunched) newspapers on top and watch it go. Better yet, skip the newspaper and use a 1/4 super cedar. It really does produce less smoke while catching just fine.
PJ
I tried the top down last winter and had a smoking mess. May try it again cause now i have seasoned wood.
I watched that one several times just not gave it much thought great tips.
Do you think i would have better luck then my first try? Also i have a big box of fire starters called strike a fire from lowes.
It may take a bit more practice and perhaps better kindling?
If you want an easy start, get a free sample pack of SuperCedars from Thomas. Break them into quarters. One or two quarters is all you'll need to get a good fire going.
What he said! The trick is dry wood with lots of air space and a super cedar.
Thank you begreen.
I may check in on the superceders i used the ones i have now before i run out of seasoned wood last year. I could start fire with normal splits with the that brand last year before running out of seasoned wood.
What I find is that every time someone didn't have success with top down they always say "I did it just like the video. Except for...". Don't do "except for".
That may be my problem.
When i do use kindling but just 10 maybe 12.
Yeah, that did seem a bit overkill. I usually use about 3-4 pieces of kindling, but that is with N/S loading and the Tunnel of Love ® starting method.
Sincei have a thread going got a Q that just came up. I have a cast iron steamer that i just cleaned is it ok to season it with oil in my oven like cast iron pots.
I'm with BeGreen. 3-4 pieces of kindling is plenty. If you run out of kindling, no problem. A super cedar will still start the fire nicely.
I also do not use a top down fire but not a bottom up either. Just something I played around with over the years. I usually lay 2 splits in the bottom and try to form a slight Vee. On that goes a super cedar and it gets lit right away. Then I lay 2-4 pieces of kindling and on top of that goes another split. Fire is all set for several hours.
I have plenty kindling probably wont use it much since i have fire starter.
First time or two I tried a top down it didn't work well for whatever reason . . . third or fourth time I think was a charm . . . have never looked back . . . now I forget that "normal" folks don't light fires this way and I get weird looks when I light a fire like this while camping, in the fire pit, etc.
The video is showing how to get a coal bed. The reason for all the small splits that are referred to as kindling. Doing a cold start ya put the big splits on the bottom, small on top and the knots on top of that and rock and roll for hours.
Edit: It works best if you dance Gangman Style in front of the stove while the fire is starting.
Reactions: corey21
Edit: It works best if you dance Gangman Style in front of the stove while the fire is starting.[/quote]
Your funny BB.
Ill try and get some pics of my fire when get it going still not cold enough in here. I guess that will wait till in the morning.
I sucked at the top down method for the first two years for some reason. Probably a combination of less than optimal wood, using too large of splits, and a lack of patience on my part. The last two years the top down method worked very well for me.
Loved it at the deer lease down in Texas. I am the camp cook, don't even carry a rifle anymore, saying "Boys, hold my beer and watch this." starting the cooking fire top down.
Conjure up an image of amazed guys in camo.
Looking at that video again since it was brought up on another thread, for what seems like it should be a professional produced video, you would think they would have cleaned the glass.
Yeah they could have cleaned the glass before the video.
I now use 1/4 of a super ceder and 3 splits and 5 peaces of kindling.
