We installed a new wood burning insert this year, and this baby puts out some heat! The issue is that our house of course isn't laid out to really benefit in terms of heating the entire house. One room in particular towards the rear doesn't really seem to heat at all, so I'm trying to find a cost-efficient way to move some air between the two rooms.
The house is a 3-bedroom ranch style with a crawlspace and an attic. We also have The ceilings are too low to install transoms above any doors, and the bedroom doors are generally kept closed at night to keep pets out, making air movement difficult with simple fans.
We do have a central HVAC system with a decently located air return in the same room as the fireplace. We tried this solution during some cooler months, and it did seem to help, though I'm not sure it would be enough on the coldest nights. I am also weary of keeping the fan on at all times to distribute air. I suppose a secondary question is whether I should be concerned about wear and tear?
Anyways, my current idea is to install some basic floor registers in the bedroom and the living room (where the fireplace is located) and run a powered fan through ductwork in my crawlspace to push cold air from the bedroom into the living room. Does this make sense? If so, what are some things I need to keep in mind? And does anyone have an idea on what this might cost?
I've attached a rough layout of our house for a visual. It's not to scale, but it should give you some idea of what I'm dealing with. The grey vents in the illustration are air returns. Every room has a supply vent.
![Running forced air return in crawlspace to heat a distant room? Running forced air return in crawlspace to heat a distant room?](https://www.hearth.com/talk/data/attachments/299/299004-b29b6cc24817a36f8172e418ea41be1a.jpg)
