Royall Pressurized Boiler
jdurant
50
Blairsville PA
Hey Eric, I got another question for you (the guru) I was wondering if I can install a royall pressurized outdoor (wood/coal) boiler in my workshop (detached from home). I want to install it inside out of sight. I will run the chimney through my roof and tie the piping into my existing pressurized (Burnham oil boiler) and logwood coal/wood boiler. Do the outdoor boilers vent any different than the indoor ones? I want the outdoor because it is insulated and can take a larger fuel load than buying a traditional indoor wood boiler. Do you see a problem?? I live in the mountin ridgeline of Western PA
I had mine in my barn. I built an insulated, cinderblock room in there with the chimney going straight up through the roof. I used an ss Duratech insulated pre-fab chimney.
The boiler drafted just fine and operated just like an indoor boiler. I lost the benefit of the radiant from the chimney and most of the radiant from the boiler itself, but it got hot water into the basement, which is what I wanted it to do.
I believe the Royall outdoor units are basically identical to the indoor rigs, just with an insulated shell.
  • Royall Pressurized Boiler
