Roxul
Tar12
1,867
Indiana
Ok guys...I am getting ready for for my BK Princess to arrive and the insurance company is requiring mineral wool board sandwiched between sheet metal with a 1 inch between the sandwich and wall...I have noticed that there are at least 2 types of the Roxul...bats and the board in different thicknesses. What have you all went with? And is it truly a "board"?
Why is your insurance requiring that? Do you not meet clearance requirements? If they require it ask them because there is nothing in code or manufacturers requirements about it.
I am assuming they require it as it asks on their check off list? I can meet any and all clearance requirements with ease...maybe I need to get that clarified.
I have to say that sounds stupid. The idea is to leave some room top and bottom for air flow. Maybe I'm way off base.
I am with you..I will check into it further.
That is the most extreme case of a heat shield - for an non-UL stove. Modern stoves have tested and certified clearance specs - to the nearest combustible surface. NFPA doesn't require wall shielding for inspection as long as the tested clearances are honored or exceeded on a modern UL tested stove. If their underwriter doesn't get that I'd be shopping around for new insurance.
