Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
You'd make it fit the same as fiberglass insulation. You want a sound fit, but not too squished, and no gaps. That said, it takes what it takes to fill the size hole you have.
If you buy r-13, then you could simply use more layers from another bat to fill the void if needed. If you buy r-30 bats, and they are too big, you should be able to peel some back and only use what you need.
If you need help, give the dimensions of the area you need to fill around the liner, and I'm sure folks here can help you pick the right size if you are unsure.
A quick tip for using Roxul: cut it with a bread knife (or any serrated knife). It does an amazing job!
+1 to what Pen said. Add multiple layers would be my suggestion. An R12 bag contains something like 8-10 sheets of it (I just installed 7 bags) and can cover roughly 60 square feet. $35 a bag here.
I ordered Roxul while at the store because they don't stock it here. Voice mail today stating its in so will grab tomorrow. Took 5 business days. I went with the smallest pieces they had, believe its 3.5 thick by 15.5 wide and 4 ft long. I figure the smaller section will be easier to work with.
I ordered my perlite from the other big box lumberyard. They shipped it straight to my house - free.
We'll make an improved block off plate to be assured the Roxul will stay up there as far we can push it. Then our plan is to pour the Perlite in from the top.
Let me know if anyone sees a problem with the approach.
Mine drafts well and has minimal creosote without insulation in a brick chimney but for little cost and half a Saturday seems like it can't hurt.
