I built a block off plate for my Lopi Insert, pics attached,,,it's not pretty, but it works. Anyway, my stove is on an inside wall with the liner going up thru the flue and surrounding chimney. My plan is to stuff roxul down the flue around the liner, and also having it lay on top of the block off plate. Is this safe to do? The Block Off plate sits 9 inches above the stove. Disclaimer: I built the block off plate years after the install. This would be much easier to do than taking the liner out and insuating it with the wrap stuff and putting it back in, plus, I don;t think I have the clearance in my flu ( see pic). In hindsight I should have insulated the liner while building the block off plate, but I didn't, and I have lots of roxul. Or,should I start over and rebuild, as this liner is around 15-16 years old.? Anyway, thanks for any advice,,,
![Roxul-Block Off Plate Roxul-Block Off Plate](https://www.hearth.com/talk/data/attachments/315/315957-07e28620c771b1233af7c97a069ea69e.jpg)
![Roxul-Block Off Plate Roxul-Block Off Plate](https://www.hearth.com/talk/data/attachments/315/315955-f296dfad66a70688db4dc49c44e331cf.jpg)
![Roxul-Block Off Plate Roxul-Block Off Plate](https://www.hearth.com/talk/data/attachments/315/315956-620e43967f49c2f9cd8d27c83c43641f.jpg)
