I had a Voyageur Grand installed last fall. Initially I was unimpressed with the performance, however after reading on this forum I learned a ton. Switching over to dryer wood and installing a block-off plate made a very noticeable difference, but my burning temps were still always relatively low. I think I managed to get above 600F once, but I seem to cruise at around 525F.
Being the heat whore that I am, I started to look for the next mod. I read a few threads on insulating around the insert for external chimneys. I decided to drive 60 miles to the nearest Lowes with Roxul Comfortbat in stock. I bought a bag of R15 and insulated above my block off plate, around the back walls and sides, then thought maybe just lay a blacket on the top.
Here's some pics. Do you think the blanket on top is OK to do, or is it overkill and/or may produce any negative effects.
![Roxul Around Insert Roxul Around Insert](https://www.hearth.com/talk/data/attachments/183/183558-d32e55e8c863ff155e7662cfec6c64c3.jpg)
![Roxul Around Insert Roxul Around Insert](https://www.hearth.com/talk/data/attachments/183/183560-29aa47a0d8b69a5a407362425c4fcde8.jpg)
![Roxul Around Insert Roxul Around Insert](https://www.hearth.com/talk/data/attachments/183/183559-ec93e8f12b0632f1589982f6fd97345d.jpg)
