Round Oak adapter situation
crobinson98
3
Carbondale, CO
Hi everyone,
I've been doing some research and I am stumped at the moment. I have a Round Oak Square Base Door Model T-3 and a double wall stove pipe that has an 8" inner diameter and a 10" outer diameter. I need to connect the stove to the double wall pipe. I know that a 7" single wall pipe bent into an oval will connect directly to the stove, so I need to find an adapter for 7" single wall to 8" ID - 10" OD double wall pipe. I've talked to several people who don't know the answer so I thought I'd prod the crowd here. Is this an adapter that exists or would it be a custom fabrication project? Thanks for any and all help.
Here is the stove before the renovation project occured and the parts were lost to the void:
[Hearth.com] Round Oak adapter situation
Here is the double wall pipe I need to connect to:
Hi everyone,
You need the proper chimney adapter for that brand of chimney pipe. That will get you to 8" round single wall. Then you simply need a 7 to 8 increaser.
Reactions: Piney
Im back, this time looking for a specific part if anyone has an idea! I need to find a double to single wall adapter for the existing double wall pipe I have. Here is a pic of the label and unfortunately this is all I've got.
From the searching I have done, it loks like this is an old Selkirk 'Metalbestos' pipe that is no longer manufactured. The ID (8") and OD (10") match but my issue is that the new adapters that I can find online are threaded. This pipe is not threaded - see here:
The closest thing I can find for a reducer is this but it will not fit becasue it is threaded. I really at a loss here and if anyone can help me find this part I would be so so grateful!!
By threaded do you mean the slanted tabs on the adapter? From what chimney pipe I have seen they all have some tab to lock the sections together. Assuming there the same brand 1 end or the other of your pipe should receive that adapter.
From the searching I have done, it loks like this is an old Selkirk 'Metalbestos' pipe that is no longer manufactured. The ID (8") and OD (10") match but my issue is that the new adapters that I can find online are threaded. This pipe is not threaded - see here:View attachment 325449
It may be to old to get parts unfortunately some are and in that case it will need replaced
Not all have tabs or twist locks. Some are just screwed some use only bands etc
Bummer, I have reached out to selkirk to see if they can help. Thanks anyway.
Do you have house insurance? If not, a safe fab up will do. We live beyond the reach of insurers and are free to mix brands as we like. We just need to ensure things lock together etc.
Don’t do it if you don’t know what is what tho. It’s serious stuff.
