Has anyone heard of a rope type saw that can be thrown over a tree limb and then two people on either side can pull up and down, sawing through the limb?
Any time you're cutting a limb, whether it's with this tool or another, you need to cut about a foot away from the crotch. Ideally, you do a bottom cut 1/4 - 1/3 of the way thru, followed by a top cut thru, at least two limb diameters away from the crotch. That way you get a clean cut, no splitting, on the final cut at the crotch.What about when you get almost through, then the branch barber-chairs on ya?![]()
I generally make an undercut, then make a top cut about an inch or so further out to leave a hinge, if that's what you're describing. If I have a "crotch" with the branch more vertical, I might use a narrow, open-notch undercut...Any time you're cutting a limb, whether it's with this tool or another, you need to cut about a foot away from the crotch. Ideally, you do a bottom cut 1/4 - 1/3 of the way thru, followed by a top cut thru, at least two limb diameters away from the crotch. That way you get a clean cut, no splitting, on the final cut at the crotch.
Yeah, I was thinking it might be tough to cut the remaining splintered section off and get the limb to fall (picture trying to cut a 1" branch instead of a large, rounded limb.). You don't have a rigid cutting edge like you do with a pole saw. Maybe you could make the cut from a couple of different angles, not sure... All you can do is give it a go, and report back.With this, you kinda have to settle for skipping the initial bottom cut, but sometimes it's the only way to avoid climbing where one shouldn't climb.
Holey Carp, I thought 18' was getting unwieldy; What are you, a body builder??I have an old-fashioned pole saw, and enough extensions for about 72 feet reach. However, I can't really lift / use it practically at any length beyond maybe 42 feet (6 foot increments). This chain saw will be handy for locations where the pole don't work.
That might work.not sure what barber-chairs means, but i guess you could start out further on the limb and work back.
nah, I'm a nerdy scientist who sits at a desk or in the lab 40 hours per week. I'll have to get a photo of this rig for you this weekend. It's pretty light, but even a 5 lb. saw blade at the end of a 40 foot pole does get a little unwieldy.Holey Carp, I thought 18' was getting unwieldy; What are you, a body builder??![]()
Holy Cow!I have an old-fashioned pole saw, and enough extensions for about 72 feet reach. However, I can't really lift / use it practically at any length beyond maybe 42 feet (6 foot increments). This chain saw will be handy for locations where the pole don't work.
Okay, guys, here's the old pole saw. I just got out two segments of 6' each, but there's a total of 8 of those in the one kit, and 6 more in another compatible kit. Also shown are the saw and lopper attachments. There's also a cast iron hook attachment, but it's squirreled away in the other kit.
View attachment 134541 View attachment 134548 View attachment 134549 View attachment 134550 View attachment 134551
I've used it at 30 feet many, many times (including yesterday). Maybe only once or twice at 42 feet. Never beyond that!Cool, do you have a photo of you using the saw at 42'?--- 72' would be even better, it'd be something us old folks could talk about around the camp fire!
I kind of wish I had a long pole saw like that Joful! I have a limb on a dead ash leaning towards my house about 25' up, and I don't really want to take down the tree unless I get rid of that limb since it's large enough to pull the tree in the wrong direction.
The "rope saw" got me thinking and I ordered a 48" off Amazon. Hopefully it cuts decent after I throw it over that limb and I can take it down in sections.
Yeah. I think for $17 it's worth a shot. I figure the largest challenge will be making sure the teeth are on the down-side to cut, so it might take a few tosses to get it working.
what are you thinking for a weight to throw it with?
