Does anyone know if Harman makes a "longer" sensor than the one which comes with the stove. I believe the sensor being made longer would enable a person to run it farther away from the stove. I see a problem here because the sensor is basically too close to the stove. I often find it difficult to find that sweet spot to put the sensor tip at where my stove runs off the true room temp. I'll set the thing for 75 degrees and if I don't have my sensor placed properly, the stove will continue to heat, even past the set room temp.
