A roof i priced out in December is 25% more expensive when I priced it out this week. But what can you do? The roof is toast. I'm not positive it would last through the winter.
I haven't heard of anyone putting foam board between strapping. Maybe we will do that before we lay down metal roofing.I'll be doing it myself. Steel roof. I'm doing a lot of extra so I won't have to do it again and to help keep the summer heat out.. Asphalt tear off, complete ice and water shield, horizontal firing straps of 2x4 with foam board in between, then metal roof on top. Luckily it's the cabin, so only 600 sq ft of roof. Still $4k with the extra work though.
I've never seen th e bottom shingle through the top before. It has me a bit worried.
View attachment 281559 View attachment 281560
I did my metal roof 10 years ago roof was around 1100 sq feet.was 1900 for material all in and I have 2 big valleys.now my friend is doing her cabin in metal and 40 year 29 ga metal is $ 1.25 a sq ft.I'll be doing it myself. Steel roof. I'm doing a lot of extra so I won't have to do it again and to help keep the summer heat out.. Asphalt tear off, complete ice and water shield, horizontal firing straps of 2x4 with foam board in between, then metal roof on top. Luckily it's the cabin, so only 600 sq ft of roof. Still $4k with the extra work though.
Yeah, I've never seen anybody do it exactly like I am. Some pretty close, but not the same way. The insulation is mostly to keep heat out in the summer. I have insulation on the ceiling already to keep the heat in come winter. I was thrown a curve ball when I found out the recommend screwing it down every 2 feet. I'd planned on 4. Not a big deal though.I haven't heard of anyone putting foam board between strapping. Maybe we will do that before we lay down metal roofing.
I assumed it was for the summer heat. Have you considered using the foil faced foam?Yeah, I've never seen anybody do it exactly like I am. Some pretty close, but not the same way. The insulation is mostly to keep heat out in the summer. I have insulation on the ceiling already to keep the heat in come winter. I was thrown a curve ball when I found out the recommend screwing it down every 2 feet. I'd planned on 4. Not a big deal though.
The drift train is leaving the stationThat's what I'll be using. I'm not sure the radiant barrier will do much given the lack of an air space over it, but there might be enough space for convection under the ribs and the aluminum may allow some conduction from the flat parts to the rib areas. The big hope is that the pure R value severely slows down the attic heating up in the first place.
There's a guy with a 50s trailer a little ways down from my place. 10 years ago he EPDMd his roof. He decided to add some slope. He placed a 6 or 8"pvc pipe down the middle and layed 3" blue board over it. I think it's styrofoam. White EPDM went over the foam. It's amazing how cool it keeps that metal box. Unfortunately I can't use white, but I can match his foam, leave the attic air space, and then make the heat work through another batch of insulation.
If I had to do my metal roof over again I would go metal shingles or metal tiles.there's a few cottages around here that have standing seam and imo do not like the look of it.The drift train is leaving the station![]()
Since we are doing a reno on an existing structure I wasn't able to put the foam on the outside of the structure, our roof overhang is very traditional (as in zero overhang). Eventually we will do the roof and have a bit more overhang, but that's more than five years out. Instead of radiant foam barrier outside we are going to use the Mylar faced bubble sheeting (3/8" thick) on the inside of our studs, followed by 1" strapping and then diagonal or vertical face nailed boards. The long term plan is to hire out a metal roof to be installed, but we haven't decided on standing seam, metal shingles, or maybe even a copper roof if economics improve.
I'm also considering wooden shingles, but really I just want whatever will last the longest.As someone who is on roofs all the time stop putting metal on every damn roof.
Do the grippy shoes help? I figured cedar shingles would be easier to walk on.Those aren't any better lol. Metal is a great roof I Just hate having to work on them
Yes but it depends on the pitch. New cedar isn't bad. Once it gets old I won't step on themDo the grippy shoes help? I figured cedar shingles would be easier to walk on.
Is that for fear of falling down or breaking shingles?Yes but it depends on the pitch. New cedar isn't bad. Once it gets old I won't step on them
Both. If you break shingles many times that will cause you to fallIs that for fear of falling down or breaking shingles?
I lived in an old plantation house converted to apartment building back in the early 90's and it still had a slate roof. A few houses in town also had them, but they have all probably been replaced by now.To continue the drift a bit, eastern white cedar shake roofs can and do last 100 years. Add in a ice and water shield underlayment and they are hard to beat plus its a local sustainable product near your location in Maine. The key is you need to go with thicker than standard shake which means buying them custom. Check out this place in Corinth Maine (NE of Bangor)https://www.dowseasternwhiteshingles.com/ . Its nice fit for Maine.
Sadly slate roof shingles used to be made in Maine (Monson) . They also would last 100 plus years but are a very expensive option.
Monson Slate AKA Shelden Slate is still going strong and you're correct, It aint cheap by a long shot.To continue the drift a bit, eastern white cedar shake roofs can and do last 100 years. Add in a ice and water shield underlayment and they are hard to beat plus its a local sustainable product near your location in Maine. The key is you need to go with thicker than standard shake which means buying them custom. Check out this place in Corinth Maine (NE of Bangor)https://www.dowseasternwhiteshingles.com/ . Its nice fit for Maine.
Thanks, I guess I was sort of right, they get the raw material from the quarries in Monson and then process the raw slate in New York.Monson Slate AKA Shelden Slate is still going strong and you're correct, It aint cheap by a long shot.
What’s strange is it must be low volume shipping as I don’t see a lot of truck traffic that could be slate moving around the area.Thanks, I guess I was sort of right, they get the raw material from the quarries in Monson and then process the raw slate in New York.
