Hello. I just installed a wood stove and I'm trying to figure out whether I need to add something like this: https://friendlyfires.ca/products/icc-excel-chimney-roof-support.
I've got a 48" section of chimney pipe that extends 24" down through a cathedral ceiling (in the support box), and then extends 24" up through the roof hole (cut 2" wider than the chimney pipe) with another 12" section of chimney pipe on top. Using the parts purchased as a "complete set" from the stove shop and following instructions, right now the only thing supporting that 5 feet of chimney pipe is the connection at the base of the support box and the little bit of "support" from the flashing collar. I am wondering if this is sufficient? Is it advisable to add something one of the roof braces I linked above?
Let me know if I can clarify any of that. Thanks in advance for any help.
