A few years ago, a member was having an issue with the lower hinge pin on a Derco Grizzly insert.
www.hearth.com
He said that he had removed a screw that was holding the pin in place.
I believe a chimney sweep loosened the lower pin in my Grizzly (he claims ignorance about removing the screw) , so I am in a similar fix.
Does anyone here have any idea where a screw should be that would hold the lower hinge pin on place?
Re-installing door pins
I recently removed the door of my wood insert to clean the glass and install a new gasket. The upper pin was removed from the top. The lower pin had a screw retaining it; I removed the screw and knocked the pin downward. The pin stayed within the door until I removed the door sufficiently for...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
