I looked all over the boards for this but apparently nobody is talking about it. I have a 6" stainless chimney, got a 6" poly brush to clean it. When I started to push it in from the top, I realized that it would not come out. The bristles had wedged themselves in. I tried twisting it and it was too tight for that as well. So I pushed the bristles down enough to dislodge it. Went to the local store and tried pushing a wire brush into a section of chimney. Same thing happened. I had to push it all the way through to get it out. Asked the clerk and he said that you had to push the brush all the way through to the stove so that it can expand and come back through the other way. None of the product manuals (Drolet stove, Selkirk chimney, Rutland brush) say anything about this. Unfortunately I didn't pay close enough attention to the construction of the stove to see if there was a big enough opening in the top for the brush to clear this way. My stove pipe and chimney go straight up and out with no elbows. But from the image in the manual where they talk about the bypass damper, it appears that this space doesn't exist. And some of the stoves at the store (other brands than mine) had a damper at the outlet of the stove.
So what am I missing? Are you supposed to be able to reverse the brush mid section in the chimney? Doesn't feel like it is possible. If not, then how do you clean it without taking the stove pipe off? Is there another type of brush that is reversable?
