I have had enough with oil prices so I've decided to resurrect the old Timberline in my house. Chimney inspector friend came said I need a liner so I purchased a flexking pro with insulation to run line the chimney. Ive been reading on how to make the old girl more efficient so i have a few questions.
The perivious owner had some water pipes in the side of the stove and some type of baffle. I have seen flat baffles but this appears to have a good 45 degree rake upward rear to front.
Are these tubes acceptable for the secondary burn holes or do they need reconfigured?
Is my baffle too angled to be effective?
I purchased some firebrick and lined the top of the baffle to insulate the firebox more.
i was thinking of running some preheating pipes around the back and into the ports in the side. How important is the actual secondary burn hole size within the tube itself?
thanks in advance for your assistance and advise.
![Resurected Timberline possible secondary?? Resurected Timberline possible secondary??](https://www.hearth.com/talk/data/attachments/164/164902-f46ce893c8e3e065b468e6700eae06f8.jpg)
![Resurected Timberline possible secondary?? Resurected Timberline possible secondary??](https://www.hearth.com/talk/data/attachments/164/164903-b440f272e1d9af405b36ee44bca23225.jpg)
![Resurected Timberline possible secondary?? Resurected Timberline possible secondary??](https://www.hearth.com/talk/data/attachments/164/164904-d149da25c996c1d5cbc61ccc1f54e89d.jpg)
The more I look at the above pic. Do you think the larger rectangle portions filled with water at one time? If so could I add secondary air holes to the rectangle portions?
