My Makita 7900 (Makita 6401 with Mahle 7900 P&C) has been running awesome until a few weeks back. It would start on the 2nd pull, every %$&* time for 5 months but now, I can’t get it to start. I took the cover off and when trying to start it, I noticed that fuel is lightly misting out of the decomp valve even when closed. So I got a compression tester yesterday and found I have around 109psi with the valve in the close position. I've pulled the plug, dried it, blew out P&C around 20 times so I don't think there is a problem with it being flooded. I've also changed the fuel with fresh 50:1 mixed gas.
Spark? Check: pulled plug, verified strong spark (on 2 plugs) and confirmed .5mm gap
Fuel? Check: Tons of fuel in P&C and end of spark plug after attempting start.
Compression? Check BUT only 109psi with valve CLOSED. Since fuel is leaking from decomp valve when closed, I think the decomp valve is bad so I ordered another. My theory is that this is causing the no start problem BUT why would it start when the valve is open under normal operation? Seems like open position under normal operation would create a similar low compression scenario but I’m pretty new to working on 2 stroke engines so I could be way off base…
Question for those who have the Makita 64xx with the Mahle 7900 P&C or a Dolmar 7900: What is your compression at with compression valve closed? What about open?
Any other suggestions, thoughts, comments, troubleshooting ideas or creative sarcasm welcome…
