Hello!
I have s gas fireplace that I do not use. It is just a decor item that works but does not produce heat.
I would like to replace it with pellet stove.
Please, help me to understand what I need:
- can i reuse the chimney? It looks like a 6", can I use some sort of adapter 3-to-6 for it?
- what do I need to know/see after removing my fireplace out?
The hole is like 63" wide and 50" toll from wood trims. I want to remove everything and put the firestove in, not insert, the standing pellet stove. I am looking into ComfortBilt HP22.
Thank you!
Chimney output:
Fireplace:
I plugged in the whole with insulation:
Thank you!
Chimney output:
Fireplace:
