Hi everyone - as the title suggests, we have decided to replace our insert with a jotul F400. ive been looking through old posts to figure out how to do it (i called a local company to see if theyd do the install but they refused, saying i just needed a better insert). There is already a flexible liner running all the way up the masonry chimney. Ive figured out that i need to make a blockoff plate, and insulate with rockwool. the plan is to push the flexible liner up a few inches, along with the existing 'collar' (i dont know the technical term) that was used to run it into the insert (it is a male connector), and have it sit on/run through the block-off plate, into a T-piece which will then run into the stove (with rear-vented configuration, obviously). So here are my questions:
1. are there any issues with pushing the flexible liner up 6 or 7 inches (ie. condensing it)? or maybe a bit more than that, depending what the T-connector looks like...? i have never worked with it before, no idea how fragile or if it has a propensity to lose its shape with such manipulation...
2. it seems to me that the blockoff plate will be performing a structural role here, in holding the flexible liner in place...is that ok?
3. any other general caveats/concerns/ 'youre f-ing crazy' comments appreciated also (i did already extend the hearth pad, clearances should not be an issue
thanks for any advice/input!
) thanks for any advice/input!
![[Hearth.com] replacing insert with freestanding stove - need installation advice [Hearth.com] replacing insert with freestanding stove - need installation advice](https://www.hearth.com/talk/data/attachments/318/318243-082af715dcac4763b81fe96a8839d7ec.jpg?hash=a2KRgWpYOP)
![[Hearth.com] replacing insert with freestanding stove - need installation advice [Hearth.com] replacing insert with freestanding stove - need installation advice](https://www.hearth.com/talk/data/attachments/318/318244-bdf14d4fc05bc58fe8e8937b15366ad3.jpg?hash=x0spCNsgM-)
![[Hearth.com] replacing insert with freestanding stove - need installation advice [Hearth.com] replacing insert with freestanding stove - need installation advice](https://www.hearth.com/talk/data/attachments/318/318247-65687e7ed2884cccf8ece705c11ebc3d.jpg?hash=kNP2JIP02G)
![[Hearth.com] replacing insert with freestanding stove - need installation advice [Hearth.com] replacing insert with freestanding stove - need installation advice](https://www.hearth.com/talk/data/attachments/318/318252-e0bd723c66fc84e9f66a88e4c93162d9.jpg?hash=Bo4AtmuEnW)
