Hey all,
Thanks in advance for the help. I have no idea what I'm doing, but drew some pictures and listed my questions at the bottom to try and make it easier.
I currently have an insert that has a loud fan and is not efficient. I have acquired a free standing stove with a secondary burn chamber that I'd like to install in it's place.
Here's my current setup:
Stainless steel flue liner screwed directly into the top of the insert. Original flue plate was removed and some level of insulation was installed, but I'm afraid I don't remember how, or what was put in it's place. Metal plate covers the rest of the fireplace opening. This was done by a licensed professional, to code.
![Replacing current insert with freestanding stove Replacing current insert with freestanding stove](https://www.hearth.com/talk/data/attachments/263/263476-403cef4055ba2b67018c154cbd1b61cc.jpg)
The model of the freestanding stove is: Warnock Hersey 24-IC. Sorry I don't have a better pic of it. It's getting sanded and painted.
![Replacing current insert with freestanding stove Replacing current insert with freestanding stove](https://www.hearth.com/talk/data/attachments/263/263477-2b0b149058ea00599091204a25c8b5a7.jpg)
Here's what I envision:
![Replacing current insert with freestanding stove Replacing current insert with freestanding stove](https://www.hearth.com/talk/data/attachments/263/263479-3b066215a73973e86d2a123fe78b2c9c.jpg)
![Replacing current insert with freestanding stove Replacing current insert with freestanding stove](https://www.hearth.com/talk/data/attachments/263/263480-7a45b3021c5a2749d0bd55a614de350d.jpg)
Here's the back of the stove and plate cover.
![Replacing current insert with freestanding stove Replacing current insert with freestanding stove](https://www.hearth.com/talk/data/attachments/263/263481-7ce6fd06d609b43a1f571f54b08d6b87.jpg)
![Replacing current insert with freestanding stove Replacing current insert with freestanding stove](https://www.hearth.com/talk/data/attachments/263/263482-19f77b64f44525bb23d2ea982e134b33.jpg)
- In the first diagram. Number 1 is how I imagine I'll attach the pipe. I believe this is the correct way to do this with a T fitting, as per shown in this thread: https://www.hearth.com/talk/threads/rear-vent-wood-stove-through-masonry-fireplace.110725/ Is this so you can open the bottom and easily clean the flue liner? Should it just be an elbow joint instead?
- Number 2 in the first diagram is just to illustrate that I'm putting the stove next to brick.
- Number 3 will be a hearth pad that is at least 8 inches on the sides and 18 inches in front for the door. The stove is pretty big and I could not find a commercial one that will be the right size so I think I'll be building my own. Any advice here would be great. I'd rather buy one, but if it's $600+ like I've been seeing online I think I'll build.
- Number 4 is just to illustrate there is carpet here. I may remove it based on advice here, but I think as long as I keep the R rating at least 1.5x what it should be and I make sure the hearth is bigger than what is required for code I will be okay.
- I'm not sure what to do about the area for Number 5. Should I make a new plate to block this area off or just leave it like it is in the illustration?
- The next illustration is because I'm really not sure how to properly insulate and block off the bottom of the chimney once I get the old stove out. Can I put non-combustible insulation and board there with a hole in it for the pipe? Should I replace the cap at the top of the chimney with one of those chains that allows you to pull it completely shut?
- I posted pictures of the 8 inch hole in the stove as well as the plate because I'm not sure how pipe attaches to it. A link to what adapter or plate I should get would be great.
