Hi Folks! New to the forum and thank you in advance for any advice! We just moved into a new home and are replacing a rear-vent stove (an old EPEL stove) which appears to be missing some parts. The chimney has an entry hole for the stove pipe quite low down so the obvious choice is a rear-vent stove like what we have now, but it seems like the only options I can find are Vermont castings and Hearthstone CAT stoves, and I'm concerned about these being tricky to use and light and leaking smoke into the house on re-fills. I had basically decided on the Hearthstone Manchester or Shelburne rear-vent stoves but am having doubts now about CAT stoves being to finicky. We want guests to be able to easily operate the stove and also I want my wife to be able to use it if they follow precise instructions, so not too finicky is very important. The chimney / Flue is high (~30 ft?), not sure about the draw. With the current EPEL stove its terrible, the house fills with smoke whenever we try and use it, but the stove is a mess.
So my question for the group is: Am I right to be concerned that the Hearthstone Manchester or Shelburne will be too finicky because they are CAT stoves? And if so, could there be a way to install a top venting stove into this space, since it seems like there are not many options for rear-venting , they all appear to be CAT stoves.
Also important is that heat output is not the primary concern here as our house has heat pumps... they do a reasonable job, but need a little help when the temperature gets very low and they don't operate efficiently they need a helping hand from the fire, but mostly we like to fire because we love to relax by a fire and watch it. So its important that the stove look nice, and have a nice viewable fire, and be easy to use.
We love the look of the Hearthstone Manchester and Shelburne but I'm worries about ease of use with these CAT stoves. Photos of the existing install attached.
Thanks all in advance for any advice!
best-
N
![Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions. Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions.](https://www.hearth.com/talk/data/attachments/292/292577-ac3ea30df0ebb741d8d4fafbd7b93059.jpg)
best-
N
![Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions. Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions.](https://www.hearth.com/talk/data/attachments/292/292574-1680d89c352d8e75805ac15bc7f10be2.jpg)
![Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions. Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions.](https://www.hearth.com/talk/data/attachments/292/292575-f67f1a299b1c041adf95f75bb0b88ee7.jpg)
![Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions. Replacing a rear vent stove, might it be possible to use a top vent in this space? Looking for easy to use stove suggestions.](https://www.hearth.com/talk/data/attachments/292/292576-a9730b3862486216da6c7eaf37e9da71.jpg)
