Hi,
I was trying to fix some exterior covering to my fireplace and upon opening found that there was a lot of rust and corrosion. I am assuming I am going to have to replace it completely. I'm not getting a lot lot of help locally I've talked to 2 fireplace dealers and they barely give me the time of day so I'm looking to do some research on my own to start. The fireplace is a Majestic ESF-II
Based on the attached photos, is it safe to say I can just disconnect the stovepipe and whatever else I can find and just push/pull the unit off the exterior of the house? It appears to me since it's all external I can do that.
Once it is all gone including the stovepipe, fake chimney, etc. Would I be able to find a replacement to drop in? (I would hire a company to do this all) What I really want to know is can the brick work on the interior remaining largely intact. I'm making a huge assumption if the main opening is compatible with a stock fireplace it could be installed. Maybe with a little modification for example the side vents being closed up. Could a brick mason do that?
Thanks,
Mark
![Replacing a prefab fireplace Replacing a prefab fireplace](https://www.hearth.com/talk/data/attachments/230/230387-e5b44932a25c318a7b8b01843a51fe08.jpg)
Thanks,
Mark
![Replacing a prefab fireplace Replacing a prefab fireplace](https://www.hearth.com/talk/data/attachments/230/230383-8a85b74673024998eeae1f120f7838e4.jpg)
![Replacing a prefab fireplace Replacing a prefab fireplace](https://www.hearth.com/talk/data/attachments/230/230384-ef51b9a2697779cd3ec314402245f5fd.jpg)
![Replacing a prefab fireplace Replacing a prefab fireplace](https://www.hearth.com/talk/data/attachments/230/230385-576aefec7fb7386e53f43635623f95f7.jpg)
![Replacing a prefab fireplace Replacing a prefab fireplace](https://www.hearth.com/talk/data/attachments/230/230386-28a0b54427c7fc6bade074eab6038cd2.jpg)
