All. I'm a long time lurker very good tid-bits of information on here. Now its my turn to ask... I just moved and in turn moved away from my HE wood insert... I now have a 1998 Majestic Zero Clearance Fireplace Model SC36 with the accordion style doors thinking it may work for the winter we tried our first burn.... TERRIBLE
Used a ton of wood and little heat even with the fan.
Now, I am setting out to start over and install a useful unit. I stopped by my local Fireplace shop for recommendations, wasn't so impressed but it was somewhat informative, This is what I know:
1. I need a Zero Clearance High Efficiency Wood Burning Fireplace, thru my online searches I have found MANY manufacturers not just a couple, What is the best bang for your buck? I am looking to keep it around $2,000.00-$3,000.00, Space is available as I am tearing out the old including the architectural stone and I would like to be able to burn a larger log, our house is roughly 2400 sqft+finished basment. I did see that most manufacturers offer remote space heating taps and distribution option with their fireplaces, I would like this option. My fireplace is located on first floor and basement is finished which is where my heat would "dump" I am a HVAC Engineer by trade and perform HVAC work for a living so this work is very feasible for me. I have a limited budget so cost is the primary driver on this, this unit does not need to be a name brand. Recommendations welcome!
2. Upon visiting my local retailer he said all flue would have to be replaced because each manufacturer of fireplaces specifies flue vent. While searching, I have found that they do, however each specifies the same type of flue but a different manufacturer(Selkirk, metalbestos,... and so on. dual wall 304SS inner and various outers with 1" mineral wool or ceramic). Unfortunately, I am not as savvy with Fireplaces as I am with Air Handlers and Boilers so currently my Majestic has a SK8- 8" flue. Can this remain on a new HE unit or will in fact have to be replaced?
If you have any other questions please ask, I am ready to pull the trigger on this but I am not sold on the manufacturer yet and am looking for industry opinions for me to research.
Thanks in advance!!
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks in advance!!
